Date/Time: Sun, 28 Apr 2024 23:45:32 +0000
Control Bar Buttons Text vs. Icon
View Count: 742
[2020-07-02 14:40:29] |
drak33 - Posts: 20 |
Is it somehow possible to reset the Control Bar Buttons identification from Text back to Icon? I lost now my orientation among buttons, because all are designated only by Text. Many thanks.
[2020-07-02 18:31:07] |
Yes you can convert them back. Refer to the first entry in the notes here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-02 18:31:14
