Date/Time: Sat, 04 May 2024 07:28:05 +0000
Problème de Flux
View Count: 713
[2020-07-01 18:03:53] |
Pascal Comby - Posts: 3 |
Je ne reçois plus les Flux pour l'Eurex je trade le Bund ( FGBL) sur Sierra depuis ce matin ? Pouvez-vous régler ce problème, merci
[2020-07-02 07:36:52] |
From Google Translate: I no longer receive Fluxes for the Eurex I trade the Bund (FGBL) on Sierra since this morning? Can you fix it, thanks
There have been some issues with the EUREX today. Refer to the postings here: https://www.eurexchange.com/exchange-en/trading/production-newsboard Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 08:59:31] |
Chris32 - Posts: 50 |
(Flux = data feed)
[2020-07-02 10:46:33] |
Did you want to subscribe to the Sierra Chart Exchange Data Feed for EUREX data?
