Date/Time: Thu, 02 May 2024 05:12:00 +0000
Upgrade Issues
View Count: 484
[2020-07-01 12:05:11] |
John Mc - Posts: 32 |
I downloaded the most current SierraChartFileDownloader.exe program and run it as Administrator. I getting a warning user Account Control message that I answer Yes to. Then the screen flashes and returns to where I started. I am running this in a Windows 10 Pro pc with Jigsaw and Bookmap running. I have tried closing the apps and upgrading but get the same result. What do I need to do to upgrade.
[2020-07-01 19:06:59] |
We do not know why you are having a problem running the Sierra Chart installer. Instead use the zip installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-01 19:07:05
