Date/Time: Sat, 18 May 2024 04:37:54 +0000
Chaikin Money Flow and bitcoin
View Count: 1367
[2014-01-28 10:58:11] |
yoytu - Posts: 59 |
Chaikin Money Flow on bitcoin is way off the spot and i dont know how come -1500 is ridiculous |
[2014-01-28 16:56:39] |
Look at the source code for it and make a determination as to why. If it does not meet your requirements create your own custom study. The study most definitely works properly and as designed. You can find the source code for it in the /ACS_Source folder in the folder that Sierra Chart is installed to. The information here should get you started to modify it and create your own version of it: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-09 10:22:44] |
ARDAN - Posts: 66 |
Do we have Chaikin Volatility indicator?
[2020-01-09 12:05:06] |
Ackin - Posts: 1865 |
Study from the default Sierrachart studies list Volatility - Chaikins Volatility - Chaikins other from Chaikin: Chaikin Oscillator Chaikin Oscillator Chaikin Money Flow Chaikin Money Flow |
