Date/Time: Sat, 27 Apr 2024 22:29:16 +0000
Exchange Data Feed Activation Problem
View Count: 589
[2020-07-01 08:00:46] |
mbilyanov - Posts: 62 |
Hi, My balance was low so my data feed subscription dropped. I topped up my account and re-activated my data feed. Just would like to make sure that I did the correct thing as now I see two payments one $20 and the other $30. Maybe I have over-subscribed to something I don't need? I would like to make sure that my subscriptions are exactly the same way they were before the cancellation. Could you please help me double check this? Thanks, M.B. |
[2020-07-01 13:38:19] |
You have activated the correct items and the Denali Exchange Data Feed is as it was before. The two payments are for the data feed itself ($25.00 USD per month) and the other is for the exchange fee ($31.20 USD per month). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-01 14:09:43] |
Thank yo very much for the answer. One final question, when I scan for $MSFT, where that historical data would come from? My Interactive Brokers data feed or SC's own data feed (I know it will not come through Denali as NASDAQ stocks are NOT on that feed)? Right now I have IB and Denali. But I guess there must be some kind of SC data in the mix as well? Date Time Of Last Edit: 2020-07-01 14:10:12
[2020-07-02 08:03:14] |
For consistent and reliable and complete US stock data you need to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service And you need to have a separate installation of Sierra Chart for this. Or you need to use the Sierra Chart Exchange Data Feed with Interactive Brokers: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-02 08:03:56
[2020-07-02 08:37:44] |
It says: The Sierra Chart Historical Data Service is included with the Standard and Advanced Sierra Chart Service Packages.
So how come it is not included with my subscription? I'm already subscribed to the Advanced version of SC and a data feed, what else I need to subscribe to for historical stocks data (NASDAQ stocks particularly)? |
[2020-07-02 08:41:39] |
We do not understand the question. What is the basis of the question? Did you follow through the instructions here?: Sierra Chart Historical Data Service What step are you having a problem with? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 11:54:18] |
Apologies, let me be a bit more clear, the question is: With my current subscriptions, can I access historical data for any NASDAQ stocks? You said that I need some other SC version for that? This is the bit I'm confused about. I would like to be able to scan through historical (1d) or intraday historical (delayed intraday data) for NASDAQ stocks. |
[2020-07-06 08:14:32] |
Yes you can but you just need to install a separate installation of Sierra Chart. This is all explained here: Sierra Chart Historical Data Service: Setup Instructions Just make sure you have a separate installation that is not using Interactive Brokers. It needs to be completely separate to avoid complications. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-06 08:14:40
