Date/Time: Thu, 02 May 2024 11:54:57 +0000
Trading System Based on Alert Condition - Exit Buy issue in live trading
View Count: 502
[2020-07-01 07:14:58] |
Rearden - Posts: 16 |
Hi, I have got an issue with Exit Buy in Trading System Based on Alert Condition. During backtests, it works as intended. During live trading, it often doesn't close all positions of a symbol but only 1 position. The "Maximum..." parameters are high enough (although I am not sure if they are even relevant for exits.). Do you have an idea, what the cause might be? (By the way, I wanted to use it as a backup for stop loss orders which sometimes get cancelled by IB -> I do need to get the Buy Exit working flawlessly). Thank you for your advice Jan |
[2020-07-02 10:52:21] |
FYI, I think that the issue can be explained by this information which I now found in the help: "The total quantity that will be exited is the lesser of the Order Quantity defined on the Trade Window or the current Position Quantity.". Problem solved (hopefully).
