Date/Time: Thu, 02 May 2024 13:18:55 +0000
[User Discussion] - [SOLVED] Error Building locally with Visual C++ and personal .h files
View Count: 2445
[2020-06-30 19:57:19] |
User106904 - Posts: 3 |
hello 1/ I had to change the bat file in ACS_Source to add the "(x86)" to the "Program Files" dir - then it started the compiler. 2/ there is a warning for unknown CL option which presumably causes the ensuing errors. 3/ does not recognize the .h files. 4/ throws an error at the end. 5/ everything works fine with the remote compiler thanks -- regards D:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" amd64 cl : Command line warning D9002 : ignoring unknown option '/std:c++17' cl : Command line warning D9024 : unrecognized source file type 'D:\SierraChart\ACS_Source\__BarEncoder.h', object file assumed cl : Command line warning D9024 : unrecognized source file type 'D:\SierraChart\ACS_Source\__basics.h', object file assumed cl : Command line warning D9024 : unrecognized source file type 'D:\SierraChart\ACS_Source\__Bracketer.h', object file assumed cl : Command line warning D9024 : unrecognized source file type 'D:\SierraChart\ACS_Source\__StringScorer.h', object file assumed ___xs22Ib_06.cpp d:\sierrachart\acs_source\__basics.h(85): warning C4244: 'initializing': conversion from 'uint64_t' to 'int', possible loss of data d:\sierrachart\acs_source\__basics.h(97): warning C4244: 'initializing': conversion from 'double' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(32): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(54): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(99): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(154): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(228): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data d:\sierrachart\acs_source\__Bracketer.h(278): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data D:\SierraChart\ACS_Source\___xs22Ib_06.cpp(254): warning C4244: 'initializing': conversion from 'uint64_t' to 'int', possible loss of data D:\SierraChart\ACS_Source\___xs22Ib_06.cpp(281): warning C4244: 'initializing': conversion from 'double' to 'int', possible loss of data D:\SierraChart\ACS_Source\___xs22Ib_06.cpp(343): warning C4244: 'initializing': conversion from 'uint64_t' to 'int', possible loss of data D:\SierraChart\ACS_Source\___xs22Ib_06.cpp(548): warning C4800: 'unsigned int': forcing value to bool 'true' or 'false' (performance warning) D:\SierraChart\ACS_Source\__BarEncoder.h : fatal error LNK1107: invalid or corrupt file: cannot read at 0x5F6 |
[2020-07-01 16:35:19] |
bradh - Posts: 854 |
If you installed Visual Studio before you installed the Visual C++ Compiler in the Sierra Chart Analysis>>Build menu, then you need to uninstall Visual Studio, reinstall the Compiler in Sierra and then re-install Visual Studio. No editing of the bat file will be required. The Warnings can be suppressed with /W0 in the Additional Compiler Parameters field. Then do "Build with Visual C++ - Debug" and when it is working re-build with "Build with Visual C++ - Release".
[2020-07-02 15:07:16] |
I uninstalled and re-installed everything in all possible orders. I think I have evidence of a problem: when .h files are used with VC NOTE >>> I am only using SC codes here that comes with SC Installation. Nothing is mine <<< >>> Scenario 1 - warnings but works - compiling ExampleCustomStudies.cpp ======================================================================== -- Starting build of Custom Studies Source files: ExampleCustomStudies.cpp. -- 16:58:36 C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" amd64 cl : Command line warning D9002 : ignoring unknown option '/std:c++17' ExampleCustomStudies.cpp C:\SierraChart\ACS_Source\ExampleCustomStudies.cpp(168): warning C4800: 'unsigned int': forcing value to bool 'true' or 'false' (performance warning) C:\SierraChart\ACS_Source\ExampleCustomStudies.cpp(169): warning C4800: 'unsigned int': forcing value to bool 'true' or 'false' (performance warning) Creating library ExampleCustomStudies.lib and object ExampleCustomStudies.exp Generating code Finished generating code -- End of Build -- 16:58:38 >>> Scenario 2 - does not work - compiling ExampleCustomStudies.cpp + IntradayRecord.h ====================================================================================== -- Starting build of Custom Studies Source files: ExampleCustomStudies.cpp IntradayRecord.h. -- 17:04:57 C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" amd64 cl : Command line warning D9002 : ignoring unknown option '/std:c++17' cl : Command line warning D9024 : unrecognized source file type 'C:\SierraChart\ACS_Source\IntradayRecord.h', object file assumed ExampleCustomStudies.cpp C:\SierraChart\ACS_Source\ExampleCustomStudies.cpp(168): warning C4800: 'unsigned int': forcing value to bool 'true' or 'false' (performance warning) C:\SierraChart\ACS_Source\ExampleCustomStudies.cpp(169): warning C4800: 'unsigned int': forcing value to bool 'true' or 'false' (performance warning) C:\SierraChart\ACS_Source\IntradayRecord.h : fatal error LNK1107: invalid or corrupt file: cannot read at 0x21B0 -- End of Build -- 17:04:59 |
[2020-07-02 16:13:10] |
solved - the problem was that with VC you dont need to specify all the (personal) .h files that are needed by the cpp -- you have to do that with the Remote compiler though. Maybe a note somewhere would be beneficial. I have seen other userd falling in the same trap |
