Date/Time: Thu, 02 May 2024 01:49:27 +0000
LoadIntradayData: Load canceled
View Count: 1947
[2013-03-21 18:53:51] |
bmoney - Posts: 32 |
Earlier today I got a message stating: LoadIntradayData: Load canceled. | 2013-03-21 08:00:38 I want to know if whatever I did to prompt this message could cause any errors in the data of the chartbooks I opened and closed at the time. (I assume I closed a chartbook while it was still loading and hopefully this does not cause any errors in the data of that chartbook or any other chartbook or the sierracharts itself) Thanks |
[2013-03-22 07:06:36] |
No. This does not cause any harm at all. Sierra Chart is designed in such a way, where nothing you can do will be damaging to Intraday Data. However, if you want to delete and re-download the data, you can go to the Intraday chart and select Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
