Date/Time: Mon, 06 May 2024 11:50:45 +0000
Print range of bar above the bar
View Count: 704
[2020-06-29 15:15:39] |
grantx - Posts: 244 |
How do I print the range of a bar in ticks/pips above each bar but only if that bar is greater than a certain size?
[2020-06-29 16:11:36] |
Sawtooth - Posts: 3993 |
Use the Spreadsheet Formula study. - Set the Chart Region to 1. - Set the Value Format to 1. - Use a formula like this in the Formula field: =IF(H-L>TICKSIZE*20,(H-L)/TICKSIZE,0) - Set the 'Draw Zero Values' to No. - Set the Draw Style to Value On High. - Set the Width/Size to your requirement. This will plot the bar's range in ticks if the range is > 20; edit formula as needed. |
[2020-06-29 18:58:01] |
We recommend using these two studies: Bar Difference Study Subgraph As Text Above/Below Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
