Date/Time: Tue, 30 Apr 2024 15:28:24 +0000
Attached Order without a Target
View Count: 514
[2020-06-29 10:36:31] |
jsob - Posts: 33 |
I want to setup an order using two contracts. Both of the contracts are assigned to All OCO Groups to allow setting a common Stop and move to breakeven. One of the contracts uses a Target: Limit. I do not want to set a target for the second contract, instead relying on the Flatten button to manage that contract. How can I do this?
[2020-06-29 18:43:23] |
You need to use two independent stop orders. One set to OCO Group 1 and the other to OCO Group 2. And you will have just one Target order. All Attached Orders will have a quantity of 1 and the parent order will have a quantity of 2. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
