Date/Time: Mon, 06 May 2024 02:45:34 +0000
Bid & Ask Depth Bars Ratio is wrong
View Count: 511
[2020-06-29 10:23:41] |
User438057 - Posts: 49 |
Calculation Difference(Ask-Bid) and Ratio are the same. Looks that in Ratio the Divider is missing. |
[2020-06-29 18:28:50] |
We will check on this.
