Date/Time: Tue, 07 May 2024 10:20:23 +0000
[User Discussion] - Trading DOM customization
View Count: 1501
[2020-07-09 13:46:15] |
user2837 - Posts: 76 |
Thank you. That is probably it. How do you I change the time frame of the invisible chart that underlies the DOM? I have looked under chart settings (F5) without any luck.
[2020-07-09 13:51:29] |
User907968 - Posts: 802 |
The same way as any other chart. Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Changing Chart Bars Period |
[2020-07-09 14:17:51] |
Thank you. I had looked in that area but the 0-5-0 syntax was a little too cryptic for me.
[2020-07-09 14:48:27] |
joshtrader - Posts: 439 |
Cryptic? It clearly states "Days-Mins-Secs Per Bar" - knowing how to change the time frame of a chart is something you should learn on day 1 isn't it? A little documentation reading goes a long way!
Date Time Of Last Edit: 2020-07-09 14:49:04
[2020-07-09 15:59:51] |
What a nasty and unpleasant fellow you are!
