Date/Time: Mon, 06 May 2024 18:49:29 +0000
TPO chart data display
View Count: 559
[2020-06-28 20:15:23] |
DF86 - Posts: 14 |
Hi some of the tpo seems to have detached and is showing differently to the rest of the data, I cant work out why. I have uploaded a screen shot the green arrow points to the data in question. The other sections of data start with an "A" whereas this starts at "M" and has a small amount of data, its the only one that has done it. http://www.sierrachart.com/image.php?Image=1593375045313.png Date Time Of Last Edit: 2020-06-28 20:18:04
[2020-06-29 03:07:05] |
And what time does the letter M represent? Refer to: Time Price Opportunity (TPO) Profile Charts: Customize TPO Letters And if you remove the TPO Profile Chart study from the chart you can then see the underlying data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
