Date/Time: Thu, 02 May 2024 01:51:59 +0000
Time incorrect on chart
View Count: 878
[2020-06-26 23:31:15] |
User721155 - Posts: 7 |
I am not sure what I am doing incorrectly but the time zone on my chart is incorrect even though I have the correct time zone chosen. I think it used to be correct, but I don't know when it changed. For instance, right now it is 4:22 pm where I am. The time on the bottom of Sierra Charts says the same, the time on my actual computer says the same time, but my chart shows as 2 hours earlier (last printed bar on the ES shows 13:57 pm). At first I thought maybe the time zone had reverted and I was correct. Strange because I definitely set it to Phoenix when I first started using Sierra Charts a few days ago. However, even though I corrected it the chart is still 2 hours behind. I went through all the help topics I could find on this and I cannot figure out how to fix it. I think maybe it happened when I tried adding the study to highlight the off session. Or that could have just been when I noticed it. I took that study off and it still isn't fixed. How do I fix it? Thanks!
[2020-06-29 06:47:04] |
We are not completely clear about the issue. However, refer to help topic 38: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
