Date/Time: Mon, 06 May 2024 18:01:25 +0000
verify sc can see funded interactive brokers
View Count: 799
[2020-06-26 17:38:01] |
whats1thingnow - Posts: 407 |
is there a way i can verify sc can see the funded interactive brokers account before july 1st for the cme funded account requirement? it seems like i have successfully connected to interactive brokers via sc, but i am not sure if i get this confirmation, i will likely switch to denali next month thank you for your help! :) |
[2020-06-26 19:38:13] |
You are running an older version of Sierra Chart. You really need to update Sierra Chart to the latest version: Software Download: Fast Update The information you are looking for is given in the Window >> Message Log when connecting to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 19:40:07
[2020-06-26 21:00:55] |
thank you for your answer - i upgraded to 2125 to get denali 'for nonprofessional Trading accounts' prices, i simply need to log in at the beginning of every month and look for last line? Interactive Brokers | TWS server version: 136 | 2020-06-26 16:46:45.384 Interactive Brokers | TWS time: 20200626 13:46:45 PST | 2020-06-26 16:46:45.384 Interactive Brokers | Connected. Sending Start API command. | 2020-06-26 16:46:45.634 Interactive Brokers | Waiting for account information. | 2020-06-26 16:46:45.634 IB Account information received. | 2020-06-26 16:46:45.637 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2020-06-26 16:46:45.637 Interactive Brokers | Connected to Live account. | 2020-06-26 16:46:45.637 Interactive Brokers | Connected to data and trading server. | 2020-06-26 16:46:45.637 Updated verified funded futures trading account ending date to: 2020-07-26 20:46:46 | 2020-06-26 16:46:45.637 thank you for confirming! |
[2020-06-28 06:25:05] |
Yes.
[2022-05-31 22:05:09] |
on my main instance, i clicked - message log > clear log - file > disconnect - file > connect to data feed the only thing i see is: Usage end date: 2022-06-09 | 2022-05-31 18:00:07.059
no lines that contains 'updated', 'verified', nor 'ending date' other than connecting to data feed, what do i need to click to see verified message in the Message Log? thank you |
[2022-05-31 22:30:56] |
All we can say is that the verified trading account ending date is now June 30 for your account. So you are just fine. Nothing further you need to do.
[2022-06-02 19:49:18] |
DabbaDo - Posts: 146 |
This also concerns me. I'm not able to see if my status is non-Professional with IBKR now. Can you check it? Is there any way to expose that status to me on the Account Control Panel (or somewhere)? Thanks, DabbaDo |
[2022-06-02 21:15:00] |
John - SC Support - Posts: 31401 |
Your Professional/Non-Professional status along with the Trade Account Verification Date for Non-Professional status can be found on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
