Date/Time: Sun, 05 May 2024 09:43:37 +0000
Clear Current Bid/Ask on new position
View Count: 868
[2020-06-26 14:44:27] |
User993067 - Posts: 142 |
Global Settings > chart DOM settings > Clear Current Bid/Ask on new position box is checked...works live and on replay, but not in sim acct?
[2020-06-26 19:33:41] |
This is the way it functions. You will find the information on this here: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-11 20:51:23] |
User120942 - Posts: 71 |
@Sierra Chart Engineering It seems strange to me that there is a global setting that only works in Live and Replay but not Sim mode. Can you provide some insight as to why this settings is not available for SIM mode? I recall this working across all three modes in earlier versions of Sierra Chart. If this functionality cannot be made available via the "Global Settings > Chart DOM Settings > Clear Current Bid/Ask on a new position" checkbox, would someone please provide an alternative workaround that can achieve the Clear Current Bid/Ask on new position setting functionality in SIM mode? Thank You |
