Date/Time: Mon, 29 Apr 2024 21:21:26 +0000
Editing the sim account dialog drop down from trade window
View Count: 564
[2020-06-26 10:35:02] |
User128888 - Posts: 30 |
Attached is the screenshot of where I'm talking about. I see two Sim1 and an account. I looked at the docs and it seems like it should be Sim1, Sim2, Sim3, etc. Also in my setting I have set to 1 Sim. Thanks.
Private File |
[2020-06-26 20:51:43] |
Are you seeing this in a sub instance of Sierra Chart? You can control the number of simulation accounts with this setting: Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General) Being it is now supported to replay Non-simulated account order fills, the live account will also be listed when in Trade Simulation Mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 20:52:28
