Date/Time: Mon, 06 May 2024 17:49:35 +0000
Live data on second system?
View Count: 531
[2020-06-26 07:11:13] |
User44790 - Posts: 20 |
Hello, I would like to ask you can I have Live streaming data on both systems if I pay for LIVE data? Or it is needed to pay for second system another $$$$ Thank you |
[2020-06-26 11:21:08] |
What exchanges did you want to get data for on another system?
[2020-06-26 20:02:21] |
CME or EUREX
[2020-06-29 14:57:59] |
Can anybody help me?
[2020-06-29 15:41:22] |
John - SC Support - Posts: 31401 |
For right now, you can only get the CME data on a second computer (the Denali Exchange Data Feed). To do this you need to pay the Exchange Fee a second time. If you want to enable this for the Denali Exchange Data Feed, then you can do so on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed There is a section entitled "Number of Systems (Computers)". If you set this to "2 system(s)" then you will be able to get the CME data on both computers. Note that when you activate this, you will immediately pay the exchange fee a second time for the month that you activate it in. Therefore, if you did this today (June 29), you would pay the full exchange fee for the last 2 days in June and then again on July 1 for the month of July. So you may want to wait until July 1 before activating the second system. We are working on getting the EUREX as part of the Denali Exchange Data Feed, which will open up the possibility of having 2 systems for that as well. But for now, it is not possible to have the second system for the EUREX data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
