Date/Time: Mon, 29 Apr 2024 01:53:13 +0000
missing intraday data for ticker REKR
View Count: 570
[2020-06-26 05:12:45] |
User346098 - Posts: 38 |
Is it possible that for some tickers there is missing intraday data? for REKR I can only see from 2019-04-30 |
[2020-06-26 19:48:07] |
What you are referring to is there is not data earlier than that date. In this particular case that date would be when trading began for that symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 19:48:38
[2020-06-27 10:11:40] |
But the daily chart shows first trading day on 2017-08-29 Also with NMTR in daily chart data starts from date 2020-05-04, but on Interactive Brokers and tradingview there is daily data from July 2016 |
[2020-06-27 22:36:05] |
We tried pulling REKR Intraday data directly from our data provider but we could not get any further data back in time than 2019-04-30. We do not see how we can do better with this either: Also with NMTR in daily chart data starts from date 2020-05-04,
It could be what is happening is that these are new symbols but existing companies which have undergone symbol change. If you know the old symbol you can just use the old symbol to get data further back in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-27 22:36:22
[2020-07-02 13:33:58] |
regarding NMTR yes there was a merge and a symbol change I also noticed that there are stocks even after "Delete all data and download" they don't adjust for stock splits per example: NNDM 2019-10-22 there was a reverse split 1 to 10 but the graph isn't adjusted. |
[2020-07-02 18:30:33] |
We will check on that stock regarding a split adjustment.
