Date/Time: Mon, 06 May 2024 09:01:01 +0000
Update from v2109 to 2125 causing chart dom color change issues
View Count: 525
[2020-06-25 16:18:23] |
User666658 - Posts: 3 |
After updating from v2109 to 2125, it's causing chart dom color change issues even though the same colors are being used for the chart/dom. If I revert back to 2109, the issue goes away, so there's something specific in this update which is affecting my charts. Thanks for your assistance, the support board which has helped me through any technical issue I've had up until this point, but its an update specific issue. If you need a recording demonstrating let me know thanks. |
[2020-06-25 18:55:05] |
Is it a problem with the Ask side and Bid side background colors? Check the color settings: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM With some color settings you will notice an "Enable" option beside it. If you want to use that color, make sure that option has a checkmark by it if available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-25 18:55:43
