Date/Time: Sun, 05 May 2024 12:15:36 +0000
Trade Activity Log NOT showing Orders_All Activity Selected in the Dropdown
View Count: 598
[2020-06-25 14:56:42] |
User631345 - Posts: 29 |
Hi, Can you please have a look at the following issue: Trade Activity Log NOT showing Orders. All Activity Selected in the Dropdown - PROBLEM HERE Trade Orders Window showing the Orders and Trade Chart Stats showing the Accumulated P&L - THIS LOOKS CORRECT Please have a look at the screenshots attached Chart Status_June 25 2020 Trade Activity Log_Empty_June 25 2020 Trade Orders Window_June 25 2020 Thanks |
Private File Private File Chart Status_June 25 2020.PNG / V - Attached On 2020-06-25 14:54:38 UTC - Size: 49 KB - 202 views |
[2020-06-25 18:20:04] |
You need to first look at the Trade Activity tab by selecting "Trade Activity" at the top of the log to see if you see the order activity there. And try also using an earlier starting date. Press the Apply button after changing the settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-25 19:00:31] |
You need to first look at the Trade Activity tab by selecting "Trade Activity" at the top of the log to see if you see the order activity there ==> On doing this and clicking on Apply, I dont see any order activity there. This is what i have sent you the screenshot of ie Screenshot called- Trade Activity Log_Empty_June 25 2020 And try also using an earlier starting date. Press the Apply button after changing the settings==> On using an earlier date it gives me details of the earlier day but not today. When I put in From date as June 24Th 2020 and To date as Today (checkmarked), and clicked on Apply, it gave me details of my trades only for yesterday and not today Please view attached screenshot: Trade Activty Log Since Yesterday. Ive checked all the orders in there and all of them are for 24Th June. None for 25Th June Thanks |
Trade Activty Log Since Yesterday.PNG / V - Attached On 2020-06-25 19:00:10 UTC - Size: 658.24 KB - 212 views |
[2020-06-26 05:50:16] |
This indicates there is some problem with the trade activity data file for June 25, 2020 for the trade account. Check the TradeActivityLogs subfolder in the Sierra Chart installation folder for that file. ---- Unrelated but additional information: Also, make sure Edit >> Filter Initial Fills Part of Existing Position is unchecked on the Trade Activity log. For more information related to this, refer to: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 05:50:32
