Date/Time: Mon, 06 May 2024 09:33:33 +0000
Stop and target attached order disappear after log off
View Count: 561
[2020-06-25 10:25:28] |
YT Lim - Posts: 32 |
Hi, I realized my stop and target attached orders disappeared after I log off, leaving me with open naked position overnight. The feature of "server side bracket order" is enabled. How can I prevent this from happening again? Did I miss anything? Thanks |
[2020-06-25 10:55:00] |
No this is very unlikely to actually be true. We do need to explain this more clear to users. What you are seeing is related to the multiple server configuration for the Sierra Chart Order Routing Service where each server works independent from each other. The Target and Stop orders are still safely working and you will see them when the parent order fills. They are on the server that they were submitted to. This is explained here: Attached Orders: Reconnected to Different Server (Child Orders Disappear) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-25 10:55:34
