Date/Time: Mon, 29 Apr 2024 11:31:50 +0000
Global settings color name - crosshair axis text
View Count: 1241
[2020-06-24 14:58:22] |
User790545 - Posts: 41 |
What is the global settings color name for crosshair axis text? Can't seem to find this.
Screen Shot 2020-06-24 at 7.55.07 AM.png / V - Attached On 2020-06-24 14:57:29 UTC - Size: 57.26 KB - 278 views |
[2020-06-24 15:04:36] |
Ackin - Posts: 1865 |
Chart Values: Color of the Price and Time Boxes Graphics Settings: Chart Values: Color of the Price and Time Boxes |
[2020-06-24 15:12:49] |
Also, what is the text color for the "net change up" and "net change down" fields?
Screen Shot 2020-06-24 at 8.11.38 AM.png / V - Attached On 2020-06-24 15:12:40 UTC - Size: 23.31 KB - 220 views |
[2020-06-24 15:15:11] |
@Ackin, yeah that changes the background color of the box but doesn't seem to affect the text color itself.
[2020-06-24 15:18:44] |
ah "text" sorry
[2020-06-24 15:34:19] |
Look: Chart Values/Crosshair Tool The chart text color will be used. Date Time Of Last Edit: 2020-06-24 15:35:23
[2020-06-24 16:17:39] |
Hmm, do you mean to set my chart text color? It's been set to a light color. Still doesn't affect the crosshair text color.
Screen Shot 2020-06-24 at 9.15.54 AM.png / V - Attached On 2020-06-24 16:17:34 UTC - Size: 271.08 KB - 218 views |
[2020-06-24 16:24:22] |
No.. Menu / Chart / Graphics Settings - chart / Fonts / .. "chart Text" when I give bold text it changes for both crosshair and also for chart... the color is still there black (for me) ... I don't know ... wait for support Date Time Of Last Edit: 2020-06-24 16:27:20
[2020-06-24 16:52:06] |
Ah okay. When I go through that, the "Use Global Graphics Settings Instead of These Settings" is checked.
[2020-06-24 19:40:59] |
The text color for the Chart Values tool is automatically set to be the same as the Background Color. To change the Net Change Up and Net Change Down colors refer to the following setting and the one after it: Graphics Settings: Net Change Up Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-24 22:01:39] |
Is the text color for the net change up and net change down boxes in the chart header also set to be the same as the background color?
[2020-06-25 14:25:10] |
Yes.
[2020-06-25 15:07:23] |
Any chance that a new release can unlink the text color from the background for unique definition?
