Date/Time: Sun, 05 May 2024 06:22:48 +0000
TradeStatistics
View Count: 736
[2020-06-24 09:31:14] |
gfx2trade - Posts: 48 |
Hi, I added the s_ACSTradeStatistics to my code. it works fine for ClosedProfitLoss() and TotalTrades() But it does not compile for TotalShortTrades() and TotalLongTrades() ... Also, it there a list of all available s_ACSTradeStatistics functions ? s_ACSTradeStatistics TradeStatistics;
sc.GetTradeStatisticsForSymbol(0, 1, TradeStatistics); int DailyTotalPL = TradeStatistics.ClosedProfitLoss(); int DailyTotalTrade = TradeStatistics.TotalTrades(); int DailyShTrade = TradeStatistics.TotalShortTrades(); int DailyLgTrade = TradeStatistics.TotalLongTrades(); |
[2020-06-26 05:52:59] |
You really want to use this new function: sc.GetTradeStatisticsForSymbolV2() Which gives access to these member variables: int32_t LongTrades = 0; int32_t LongFlatToFlatTrades = 0; int32_t ShortTrades = 0; int32_t ShortFlatToFlatTrades = 0; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 05:54:45
[2020-07-08 15:34:18] |
Thks for the answers. I am know using sc.GetTradeStatisticsForSymbolV2(). Two question.... is there any way to set the start date for the statistics log ? i.e. I would like to have the $ since the beginning of the month. Also, is there any way to get the daily statistics for the trading account as a whole rather than the chart symbol. Thks |
[2020-07-09 06:45:05] |
Refer to: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Also, is there any way to get the daily statistics for the trading account as a whole rather than the chart symbol. Only within the Trade Activity Log itself.
