Date/Time: Tue, 10 Nov 2026 08:05:05 +0000
A few "strange" SecurityDefinitionResponse messages from DTC server
View Count: 797
| [2020-06-23 07:09:38] |
| User442651 - Posts: 25 |
After my DTC client makes a SymbolsForExchangeRequest, for the CoinFLEX exchange, the server responds with a list of 8869 SecurityDefinitionReponse messages. Most of them look as expected, but there are a handful ~10 (I can count the exact number if anyone wants) of responses that look invalid. For example, the 75th response has the symbol "(Enter Search Text - NYSE/AMEX/NASDAQ)" and a blank description. Another symbol is "(Get Deribit Symbols)" again with a blank descriptions. Are these some kind of placeholders that are to be expected, or is there something going wrong that should be addressed? |
| [2020-06-23 08:06:25] |
We will filter these out.
| [2020-06-23 08:17:11] |
We also see that DTC server request is not filtering based upon the given exchange. That will be implemented in the next release. It is not filtering on security type either. We will see about implementing that as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-23 08:17:20
