Date/Time: Fri, 18 Jul 2025 22:57:12 +0000
Same contract, same (sim) account, different chart, BUT different dayily PnL
View Count: 1409
[2014-01-27 16:01:48] |
User28286 - Posts: 24 |
I'm puzzled why 2 different trade windows on 2 different charts (1 min and 800 ticks) show different daily PnL for the same sim account? The contract is the same. Do I really even need a separate Trade Window for each chart even when the contract is the same? I simply would like to trade CL contract exactly with the same way (bracket, target, stop etc) on 2 different charts (1 min & 800 tick). Now the tick chart trade window shows trades & daily PnL correctly, but 1 min chart trade windows daily PnL is behaving real odd, eg after a profitable trade the Daily PnL decreases! even when it shows the same trade and same, correct real-time trade P/L. Please advice. Thanks. P.S. I uploaded a screenshot pic but can't see where it is... Date Time Of Last Edit: 2014-01-27 16:05:09
Private File |
[2014-01-27 22:46:09] |
Thank you for that image. It was very helpful. The problem is you have a different Position Profit/Loss format which is also used by the Daily Profit/Loss value, between the two different charts. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#ProfitLossDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
