Date/Time: Sat, 27 Apr 2024 22:22:44 +0000
connection
View Count: 620
[2020-06-22 19:07:47] |
User712893 - Posts: 11 |
Hi i am having difficulty connecting to my sierra charts, it lets me log in but stays yellow by the connection, will not go to green, i contacted amp futures and it is not something wrong from their end, can you help me out?my email is **
Date Time Of Last Edit: 2020-06-22 20:36:12
[2020-06-22 20:35:48] |
Yes we will help with this. The TT trading account assignment has not yet been done.
[2020-06-23 01:35:25] |
ok is their anything i have to do on my end?
[2020-06-23 13:42:11] |
SC Support - Posts: 1795 |
Hi User712893, Can I give you a call to help with set-up?
[2020-06-24 01:47:47] |
Spoke with User712893, helped with set-up
[2020-06-24 19:52:44] |
i am still not sure what i am supposed to do know to get this set up can you help me out?
[2020-06-24 20:51:52] |
Hi there, we can call you in a couple hours if that works.
[2020-06-24 23:23:16] |
yes great
[2020-06-25 00:19:12] |
Spoke to User712893, have sent his request to AMP to make the required change
[2020-06-25 19:00:35] |
Hi was that message i got that amp completed the setup, because it is still not working on my end?
[2020-06-25 19:06:51] |
We can call you again right now.
[2020-06-25 20:13:34] |
ok had to go can you call me back at 730 tonight?
[2020-06-25 20:24:00] |
Sorry I will ask an Engineer to call you then.
[2020-06-26 02:37:24] |
User was called. And the problem is a connectivity issue affecting the port used for the order routing service. They will contact their ISP about this.
