Date/Time: Sun, 19 May 2024 12:01:43 +0000
Custom Trail Stop - Two Step Trail to BE
View Count: 1248
[2014-01-27 12:55:49] |
Futures Operator - Posts: 239 |
I need a stop that moves to breakeven in two fixed steps, then stays there and doesn't continue to trail. ie initial at -12, at +6 move to -6, at +12 move to breakeven/0. How can I set this up?
Date Time Of Last Edit: 2014-01-27 14:21:28
[2014-01-27 16:52:44] |
We plan to add this capability. It does not currently exist.
[2014-04-25 06:02:25] |
Any update/timeframe on this?
[2014-04-25 16:49:08] |
No update about this.
[2014-04-25 19:58:33] |
User51517 - Posts: 58 |
one thing you can do is this: use the step trailing stop, and at the same time set 12 < target < 18.
Date Time Of Last Edit: 2014-04-25 19:58:59
[2014-05-01 05:35:49] |
SC, thanks, appeciate if you can add when possible, will be very useful for managing single contracts. User, thanks, could you please help me understand how exactly to set this up, and how it would work vs what was requested? |
[2014-05-01 12:39:46] |
see attached picture
step trail.png / V - Attached On 2014-05-01 12:39:15 UTC - Size: 27.66 KB - 372 views |
