Date/Time: Sat, 18 May 2024 19:51:22 +0000
Get highs and lows using horizontal line at time
View Count: 567
[2020-06-19 13:49:57] |
grantx - Posts: 244 |
Using the study 'horizontal line at time' how would I get the highest and lowest values since that line? So if I start the line at 14:00 I want to know what the highest and lowest point has been since that line. |
[2020-06-19 14:45:11] |
Ackin - Posts: 1865 |
Use another study for this finding: High/Low for Time Period | High/Low for Time Period - Extended High/Low for Time Period |
[2020-06-19 16:09:53] |
The problem is that I am using the 'horizontal line at time' as a reference for other studies which are above and below. So if that high/low for time period study had a midpoint reference to work with that would be awesome...
[2020-06-19 17:40:19] |
There are several types of settings / views in that study ... send the screen here as you set it up
[2020-06-19 18:21:54] |
Look at the screenshot. Number 2 and 3 work together because I can set number 3 to subtract from number 2 and that draws a line on my chart. BUT I cant subtract from high/low for time period because it only has a high and a low setting. I need to subtract from the midpoint. I can get around this but that involves a whole bunch of other studies and it starts getting confusing. So if the high/low study simply had a midpoint it would be very convenient. |
[2020-06-19 18:34:58] |
Midpoint? Study Subgraphs Average (with inputs High and Low from High/Low study) Study Subgraphs Average Date Time Of Last Edit: 2020-06-19 18:36:43
[2020-06-19 19:00:46] |
Yup. That works . Thanks Ackin.
[2020-06-19 19:00:48] |
The responses given above are what you are looking for. Let us know if that answers all of your questions and you and now have what you need.
[2020-06-19 19:07:13] |
Yes, I am quite happy with the result. Thank you Sierra and Ackin.
