Date/Time: Tue, 07 May 2024 18:14:52 +0000
Ver 2124 - OpenGl
View Count: 1141
[2020-06-19 11:58:50] |
NRGTrader - Posts: 351 |
Is anyone else having issue with OPenGl wherein when use Tools>ChartValues/Crosshair and hover over or right click on part of chart, the text on axes and all studies plotted turn a solid color - see attached? In this case the histogram didn't "black or grey out, but it often does as well as the time period highlight.
Screen Shot 2020-06-19 at 07.51.49.png / V - Attached On 2020-06-19 11:57:56 UTC - Size: 515.27 KB - 456 views |
[2020-06-21 21:08:09] |
Anyone having this issue? Have clocked it, but running OPenGl seems to be more responsive (i.e., faster switching from chartbook to chartbook, charts within chart books, etc). However I am constantly using crosshairs tool and this graphic issue is a dealbreaker.
[2020-06-23 19:03:18] |
UPDATE Odd situation here. This happened in 2124 and 2125. >Unhandled Exceptions in chart drawings The "odd" part is that I loaded all my chartbooks in both versions. When I received the unhandled error, I did per instructions - copied DLL to backup, started safe mode etc. - No unhandled exceptions with SC running for about 30 mins. Assumed there were no problems Reloaded all the same chartbooks in non-safe mode. Let run for about the same time period. No errors -- UNTIL As soon as I chose tools>chart values/crosshairs and moved cursor over chart and left clicked to change a chart drawing - the unhandled exception began. Also the same chart colors cycling back-and-forth from what is shown in the attachment to normal began. Seems as though the issues with both the behavior shown in attachment and unhandled exception is occurring due attempting to arrow around chart with cursor of change chart drawing. |
[2020-06-23 19:13:24] |
nosast - Posts: 290 |
You are not the only one experiencing issues with OpenGL in latest releases. Could be similar cause than expressed here: OpenGL Exception/Stability Issues
Date Time Of Last Edit: 2020-06-23 19:46:01
[2020-06-26 10:44:29] |
Updated to Version 2127. So far haven't received unhandled exception error, but the graphics issue outlined in the attachment still exists.
[2021-06-10 12:10:24] |
User1293821 - Posts: 42 |
Any update on this? I get the crosshair problem and would like it to be fixed.
