Date/Time: Fri, 26 Apr 2024 15:26:24 +0000
ACSIL : chart region
View Count: 1169
[2014-01-27 12:15:17] |
User40117 - Posts: 56 |
hello, taking first steps into SC and ACSIL. 2 questions. 1. A first test results in a graph drawn in a chart, but it is placed in a region below the chart. I discovered you can change the region but is there a way to predefine the region in ACSIL ? 2. sc.bollingerbands : SubgraphOut. For this function, sc.Subgraph[].Arrays[0-1] (Extra Arrays) are used for internal calculations and additional results output. How do i know which extra array represents what ? Upper / lover ... ty |
[2014-01-28 01:03:51] |
vegasfoster - Posts: 444 |
1. sc.GraphRegion = 0; 2. http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scBollingerBands |
[2014-01-28 07:02:35] |
thx, was able to find already tho, but you beat me to respond. |
[2014-01-28 23:33:49] |
2. It is in the example code given here: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scBollingerBands Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
