Date/Time: Sat, 18 May 2024 21:06:24 +0000
Cuenta Cerrar
View Count: 454
[2020-06-19 01:06:16] |
User897300 - Posts: 1 |
Quisiera cerrar mi cuenta (eliminar) gracias.
[2020-06-19 05:14:25] |
In this case there is nothing you need to do. Thank you. Understand there is *no* automatic billing to a credit or debit card. If you do not wish to continue to use the Sierra Chart software and services, make sure activated services are not set to renew: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures If you have a Services Balance in excess of 15 USD, you may request a refund or it can remain on your balance for future use. Thank you for using Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-19 05:15:13
