Date/Time: Mon, 29 Apr 2024 12:02:01 +0000
Alert Manager suggestion
View Count: 1115
[2014-01-27 10:20:52] |
Litz - Posts: 131 |
In the Alerts Log, have the most recent alert appear at the top of the log instead of the bottom, to eliminate the need to scroll down the log to view the most recent alert when the Alert Manager pops up.
[2014-01-27 15:11:52] |
Futures Operator - Posts: 239 |
+1. Also it would be great to simply right click on a price in a chart, and set an alert with 1-2 clicks, rather than going through the menus to find the alert manager, manually type in the complete symbol name, price, etc. |
[2014-01-27 18:39:33] |
Select the last line in the Alerts Log, it will automatically scroll when a new Alert Message is added. You can add the Add Symbol Alert menu command to the Chart Shortcut Menu. This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_AlertsManager.html#SymbolAlerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-27 18:40:04
[2014-01-27 20:14:32] |
Litz - Posts: 131 |
Yes that does work thanks. Although it means I have to click on the last alert or scroll the alert log many times a day. Just saying it would be easier throughout the day having the last alert appear at the top. Thanks for your time.
[2014-01-28 23:38:11] |
OK we will see if this is not difficult to do.
[2014-02-05 16:20:32] |
Litz - Posts: 131 |
I see the Alerts Log auto scrolls now. Good improvement. Thank you. If you could enable Settings and Sort for the Alerts Log as they are for the "Symbol Alerts", it would be a help. Don't know if it is possible
