Date/Time: Tue, 10 Nov 2026 08:05:20 +0000
Alert for change of subgraphs value
View Count: 924
[2020-06-18 08:29:56]
User361939 - Posts: 170
I am trying to get alert for change of value of subgraphs eg. study "volume value area lines" i refer to subgraphs SG2 SG3 and i just trying get info when those subgraphs change(doesn't metter how much)
Can create alert as a popup message?
Best Regards
[2020-06-18 09:05:01]
Ackin - Posts: 1865
Hi, I've created a study for these situations if you want ... try it:
Study: Text Display For Study (ColorBar Condition)
contact link:
imageSame values.png / V - Attached On 2020-06-18 08:59:47 UTC - Size: 23.13 KB - 377 views
imagechanged values.png / V - Attached On 2020-06-18 08:59:57 UTC - Size: 13.42 KB - 313 views
[2020-06-22 13:37:54]
hello,
Would you be kind to advice me how to make alert as a popup msg?
Best Regards
[2020-06-23 04:57:34]
Refer to the following setting:
General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings)
