Date/Time: Sat, 05 Jul 2025 18:22:25 +0000
[Programming Help] - Count set to 0 every tick
View Count: 753
[2020-06-17 09:43:05]
gfx2trade - Posts: 48
I want to use a counter in my studiy so that the order generation only starts after a few bars.
I use a count with ...
int periodCount;
and then
if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) {
      ServiceLogStr = "";
      ServiceLogStr.Format(" # of period since start up : %i", periodCount );
      sc.AddMessageToTradeServiceLog(ServiceLogStr, 0);
      periodCount ++;
issue it that periodCount gets reset to 0 a every tick. Therefore it never exceeds 1.
Can you please help ?
Thks
[2020-06-17 12:41:53]
Ackin - Posts: 1865
periodCount++; //without space
and next
Do you use autolooping? If not, you are missing the index in parentheses
if (sc.GetBarHasClosedStatus(Index) == BHCS_BAR_HAS_CLOSED) {
[2020-06-22 15:26:43]
hello,
thks for helping.
I do have
sc.AutoLoop = 1;
and ...
  // Data Processing
      ServiceLogStr = "";
      periodCount++;
  if (periodCount < 10) {
    ServiceLogStr.Format(" Period count is lower than 10 : %i", periodCount );
    periodCount++;
    ServiceLogStr.Format(" After ++ Period count is lower than 10 : %i", periodCount );
    IsTradeAllowed = false;
    sc.AddMessageToTradeServiceLog("-------------------- Pending further market data prior to activation --------------------", 0);
    // return;
In the end ... result is ...
# of period since start up : 0 | 2020-06-22 17:23:01.264
# of period since start up : 1 | 2020-06-22 17:23:01.264
Period count is lower than 10 : 1 | 2020-06-22 17:23:01.264
After ++ Period count is lower than 10 : 2 | 2020-06-22 17:23:01.264
-------------------- Pending further market data prior to activation -------------------- | 2020-06-22 17:23:01.264
Period count is lower than 10 : 0 | 2020-06-22 17:23:01.440
After ++ Period count is lower than 10 : 1 | 2020-06-22 17:23:01.440
-------------------- Pending further market data prior to activation -------------------- | 2020-06-22 17:23:01.440
Period count is lower than 10 : 0 | 2020-06-22 17:23:03.258
After ++ Period count is lower than 10 : 1 | 2020-06-22 17:23:03.258
-------------------- Pending further market data prior to activation -------------------- | 2020-06-22 17:23:03.258
Period count is lower than 10 : 0 | 2020-06-22 17:23:03.493
After ++ Period count is lower than 10 : 1 | 2020-06-22 17:23:03.493
-------------------- Pending further market data prior to activation -------------------- | 2020-06-22 17:23:03.493
it is like it is reset to 0 @ eack new tick.
definition is ...
int periodCount; // Gestion d'un seuil minimum de bar avant activation.
it is outside
if (sc.SetDefaults)
if inside, I get the following error message . 'error: 'periodCount' was not declared in this scope'
[2020-06-22 15:51:03]
User907968 - Posts: 840
Each time the function is called, your variable 'periodCount' will be uninitialised i.e. have no value set.
Read this to understand when the function is called using automatic looping:
Working with ACSIL Arrays and Understanding Looping
If you want the variable to retain its value between calls to the function, there are the persistent variable functions available:
ACSIL Interface Members - Functions: Persistent Variable Functions
[2020-06-23 10:41:20]
I'll have a look.
[2020-06-24 16:09:37]
Thks.
I could not find in the documentation the persistent variable for boolean.
Does it exists ?
[2020-06-24 17:20:43]
You could use sc.GetPersistentInt
false = 0
true = 1 (non-zero)
[2020-06-25 06:28:38]
Nice work around. Does it mean that there is no native solution to keep a boolean value tick after tick ?
