Date/Time: Tue, 10 Nov 2026 08:21:10 +0000
Large Volume Trade Indicator - Transparency Percent
View Count: 1847
[2020-06-16 11:39:59]
User105664 - Posts: 4
Transparency Percent would be a nice feature to add to the Large Volume Trade Indicator. Currently you can only use draw style (Transparent), but you can not change the Percent Level. It would help for percent of transparency since it is not always easy to see Transparent Volume Dots on some of the background colors.
Cheers,
Date Time Of Last Edit: 2020-06-16 11:41:03
[2020-06-16 12:53:13]
User907968 - Posts: 885
You can set the transparency percentage on the 'Study Settings' -> 'Subgraphs' -> 'Transparency Level for Fill Styles'
Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles
[2020-06-16 13:03:13]
That is not an option with this Study. Draw Style default is Ignore. The only other option available is Visible, but it will revert to ignore if you try to save it. thx..
Date Time Of Last Edit: 2020-06-16 13:04:11
[2020-06-16 13:21:37]
See image attached, setting mentioned above is highlighted
imageTransparency.png / V - Attached On 2020-06-16 13:21:26 UTC - Size: 34.86 KB - 581 views
[2020-06-16 13:27:25]
Fantastic! I did not know that.. Thx!
