Date/Time: Sat, 18 May 2024 21:55:30 +0000
SC Real Time Futures Data Feed
View Count: 962
[2014-01-26 23:32:25] |
User94740 - Posts: 333 |
Hi SC, I thought the charts were supposed to update without having to be connected to my trading platform? I have IB
[2014-01-26 23:46:34] |
No. You do have to connect to your Interactive Brokers live trading account.
[2015-11-01 23:01:43] |
I just want to make sure, but if IB is my trading platform and I am using SC real-time, should I understand the last 15 minutes are always updated by IB?
[2015-11-01 23:07:46] |
This is not correct. If you are using the Sierra Chart Exchange Data Feed, all the data comes from the Sierra Chart Exchange Data Feed for the symbols you have activated exchanges for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-01 23:33:42] |
thx, am wondering about the difference between the two options for CME full group. Do I need market depth for tpo charts?
Date Time Of Last Edit: 2015-11-01 23:55:04
[2015-11-01 23:55:27] |
Here is the pricing: Sierra Chart Exchange Data Feed: Data Feed Pricing You do not need market depth data for TPO Profile Charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-01 23:55:59
[2015-11-02 00:05:12] |
thx again. I guess I would need to make a payment for 38.25 USD. Have you considered reducing the sc connection fee price?
[2015-11-02 00:24:26] |
This is approximately the correct amount. Although the data feed is going to be prorated depending upon when you activate it. We cannot consider reducing the price of the connection because we already lose money on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-02 00:24:44
[2015-11-02 01:18:05] |
is there anyway I can ensure I am receiving the better data feed?
[2015-11-02 02:00:57] |
Yes, refer to step 8 in this section here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
