Date/Time: Tue, 10 Nov 2026 08:21:15 +0000
Price Expansion (2 point)
View Count: 1330
[2020-06-15 15:21:34]
abrown8703 - Posts: 64
SC, trying to locate in your documentation the "math" used to construct the Price Expansion (2 point) tool. Could u post or direct me to this info?
To your continued success!
[2020-06-16 00:03:54]
User90125 - Posts: 715
Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools
Using this tool involves drawing a line. To do this, left click on the chart with your Pointer to mark point A, move the Pointer and left click again to mark point B. The line A-B represents the length of price move.
The expansion/extension levels are calculated from these 2 points. If the line is down sloping, then the expansion lines will move downward starting from 0% at the bottommost point and the percentages will increase from this bottommost point. If the line is up sloping, then the retracement lines will move upwards starting from 0% at the topmost point and the percentages will increase from this topmost point.
