Date/Time: Sat, 12 Jul 2025 00:43:42 +0000
Sendind e-mail alert using ACSIL
View Count: 2007
[2014-01-26 10:29:14] |
VF56002 - Posts: 27 |
Hello, I wonder how to send an e-mail from advanced custom study. Is there any function for that? I couldn't find any in help. Thanks
[2014-01-26 23:45:25] |
This can indirectly be done by using the sc.PlaySound function: https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scPlaySound With this function you can trigger a particular Alert Number which can have associated with it both a sound file and an email message. You are also able to specify the text of the email message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-26 23:45:48
