Date/Time: Wed, 15 May 2024 20:48:02 +0000
Last 30 seconds of a Candlestick in a 1 minute time frame.
View Count: 520
[2020-06-12 13:05:05] |
User611355 - Posts: 8 |
Is it possible to show a count down on a candlestick in the last 30 seconds on a 1 minute chart?
[2020-06-12 17:50:08] |
No, not just in the last 30 seconds. You can use the Countdown Timer in general, but there is no built-in method to only display it for part of the time. You could modify the source code for the Countdown Timer study for what you want to accomplish. The code is available in Studies2.cpp. Refer to the information here to get started with this: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
