Date/Time: Thu, 16 May 2024 02:40:27 +0000
Automated Trading: Why is FilledQuantity on a stop order always 1
View Count: 472
[2020-06-12 03:21:51] |
User443056 - Posts: 2 |
When I get stopped out and I examine the stop order using s_SCTradeOrder and look at FilledQuantity it always reports as "1" even though my position size is greater than 1. The order was initiated with a stop using StopAllPrice. I notice when I try to manually move the stop the confirmation dialog also shows a quantity of 1 even though the actual position size is greater than 1. This seems like a bug unless I am misunderstanding what FilledQuantity is intended to be. Thanks |
[2020-06-12 09:41:48] |
There would be multiple Stop orders if you have multiple Targets. So each of those individual stop orders will have a smaller quantity than the total Position quantity. This is explained here: Attached Orders: OCO Group (Group) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
