Date/Time: Sun, 19 May 2024 06:58:45 +0000
Number of Bars to calculate setting
View Count: 777
[2020-06-11 16:41:41] |
User996274 - Posts: 80 |
Can you tell me what this setting in the "trading based on alert condition" study calculates and what effect it would have on an auto trading system? is it cumulative? (ie majority of bars match your auto trade parameters) Volume based? |
[2020-06-15 00:49:42] |
This particular Input is thoroughly documented in this section here: Trading System Based on Alert Condition: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-15 12:36:29] |
User875891 - Posts: 63 |
So if I understand this correctly the "number of bars to calculate" means that after a signal is generated that signal will be the "bias" for the following "number of bars to calculate"? ie if its set to 200 and a signal is generated it will only trade in that direction for the next 200 bars, then the next signal after the 200 bars will determine the next bias? "Number of Bars to Calculate: This Input defines how many chart bars for which the Alert Condition will be evaluated. The primary purpose of this Input is to reduce calculation time. It has no other practical purpose." Date Time Of Last Edit: 2020-06-15 12:36:52
[2020-06-15 19:28:09] |
No that is not correct.
