Date/Time: Sun, 19 May 2024 14:15:33 +0000
Setup Trade and Current Quote Symbol does not work correctly
View Count: 459
[2020-06-11 05:15:35] |
nicktrader - Posts: 665 |
This setup does not work correctly if you change the rollover method manually. Ver.: 2092 |
Trade and Current Quote Symbol.png / V - Attached On 2020-06-11 05:14:55 UTC - Size: 8.75 KB - 177 views |
[2020-06-11 05:28:12] |
We have no idea what you are describing.
[2020-06-11 06:06:35] |
Just tried to reproduce it and now it runs correctly. No idea why. Many thanks for your quick response |
