Date/Time: Sun, 19 May 2024 14:15:01 +0000
Top line in chart
View Count: 522
[2020-06-10 20:29:49] |
user2837 - Posts: 76 |
The top line the chart attached (es.png) begins with "ESM20[C][M] 60 min" and is followed by much other information about O, C, H, L, B, A, and so on. I want all the information following "ESM20[C][M] 60 min" to be omitted. How to do that?
[2020-06-11 05:05:48] |
Refer to: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
