Date/Time: Sun, 19 May 2024 13:39:27 +0000
J85 Allow Trading Only During Time Range
View Count: 750
[2020-06-10 20:13:23] |
User857051 - Posts: 10 |
Allow Trading Only During Time Range (read/write): TRUE Start Time For Allowed Time Range (read/write): 18:00:00 End Time For Allowed Time Range (read/write): 15:49:59 Flatten Positions And Cancel Orders At Set Time (read/write): TRUE Time For Flatten Positions And Cancel Orders (read/write): 15:49:59 Service log says ignored signal because of J28/J85. J28 was blank and I got no fills then I set J28 to 0 and got no fills. If I set J85 to FALSE I get fills so what's wrong with these settings? All I want to do is be flat from 3:50pm est to 6pm est. Please help! |
[2020-06-11 06:47:55] |
It is not possible until version 2120 which is yet to be released, to use those particular start and end times which you have which are reversed: Spreadsheet Systems, Alerts and Automated Trading: Start Time For Allowed Time Range (read/write) [J86] This is also not reliable because it is just too close to the end time for allowed trading and there may not be any opportunity to flatten: Time For Flatten Positions And Cancel Orders (read/write): 15:49:59 We recommend using some minutes earlier, just to be completely safe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-11 06:53:13
[2020-06-11 06:52:56] |
Thinking about this some more, this may not be correct: This is also not reliable because it is just too close to the end time for allowed trading and there may not be any opportunity to flatten: But still we recommend not putting it right at the ending time of allowed trading.
Time For Flatten Positions And Cancel Orders (read/write): 15:49:59 We recommend using some minutes earlier, just to be completely safe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-11 06:53:24
[2020-06-11 14:32:01] |
Sawtooth - Posts: 4000 |
Instead of using J85/J86/J87, you could use this formula in J28: =AND(FRACTIME(J41)>TIMEVALUE("00:00:00"),FRACTIME(J41)<TIMEVALUE("15:50:00")) To allow exits after 15:50:00, but disallow entries, include a reference to J8: =AND(J8=0,FRACTIME(J41)>TIMEVALUE("00:00:00"),FRACTIME(J41)<TIMEVALUE("15:50:00")) Now you can flatten at a later time in J29: =FRACTIME(J41)>=TIMEVALUE("16:00:00") |
