Date/Time: Wed, 15 May 2024 02:21:17 +0000
[Programming Help] - DTC - Cannot modify order created within Sierra itself
View Count: 473
[2020-06-10 18:52:49] |
User667559 - Posts: 27 |
I create a bracket order in Sierra on the DOM, then I would like to change the stop order via DTC. The problem is that Sierra doesn't create a ClientOrderID which is required to modify orders: The STOP order created when clicking on the DOM. { Type: 301, RequestID: 0, TotalNumMessages: 1, MessageNumber: 1, OrderStatus: 4, OrderUpdateReason: 3, OrderType: 3, BuySell: 2, Price1: 1007100, Price2: 0, TimeInForce: 1, GoodTillDateTime: 0, OrderQuantity: 2, FilledQuantity: 0, RemainingQuantity: 2, AverageFillPrice: 0, LastFillPrice: 0, LastFillDateTime: 0, LastFillQuantity: 0, NoOrders: 0, Symbol: 'NQM20_FUT_CME', Exchange: '', ServerOrderID: '7960', ClientOrderID: '', ExchangeOrderID: '7960', LastFillExecutionID: '', TradeAccount: 'Sim1', InfoText: 'Simulated order accepted', ParentServerOrderID: '7959', OCOLinkedOrderServerOrderID: '7960', OpenOrClose: 2, PreviousClientOrderID: '', FreeFormText: 'SimpleBracket.twconfig', OrderReceivedDateTime: 1591814319, LatestTransactionDateTime: 1591814431.777 } When I try to modify set order: Sending to Sierra: { Type: 204, ServerOrderID: '7960', ClientOrderID: '', Price1: 10071.25, TradeAccount: 'Sim1', Quantity: 0, Price1IsSet: 1, Divisor: 100, RequestID: 9 } I get: { Type: 301, RequestID: 0, TotalNumMessages: 1, MessageNumber: 1, OrderStatus: 0, OrderUpdateReason: 10, OrderType: 0, BuySell: 0, Price1: null, Price2: null, TimeInForce: 0, GoodTillDateTime: 0, OrderQuantity: null, FilledQuantity: null, RemainingQuantity: null, AverageFillPrice: null, LastFillPrice: null, LastFillDateTime: 0, LastFillQuantity: null, NoOrders: 0, Symbol: '', Exchange: '', ServerOrderID: '7960', ClientOrderID: '', ExchangeOrderID: '', LastFillExecutionID: '', TradeAccount: '', InfoText: 'ClientOrderID field is not set.', ParentServerOrderID: '', OCOLinkedOrderServerOrderID: '', OpenOrClose: 0, PreviousClientOrderID: '', FreeFormText: '', OrderReceivedDateTime: 0, LatestTransactionDateTime: 0 } Which makes sense. However, I would really like to modify any order that is created within Sierra itself. Can you please explain how to do that? Date Time Of Last Edit: 2020-06-10 18:53:23
[2020-06-10 18:56:07] |
Right, I think I fixed it by just giving any random string to the ClientOrderID field, this is confusing while reading the documentation, but it works.
Date Time Of Last Edit: 2020-06-10 18:59:23
[2020-06-12 18:18:59] |
You do not have to use the same ClientOrderID when modifying the order. Even though there is not one assigned, you just assign one like you did.
