Date/Time: Wed, 01 May 2024 22:22:03 +0000
Trading orders window and order of exiting positions
View Count: 591
[2020-06-10 06:24:55] |
aryan_k - Posts: 6 |
Hi, 1) I understand that individual orders can be closed using the trade orders window whist on sim. However I'm finding that the order shows up less than 50% of the time when it's placed on the depth of market tool, and when it does show, it wipes off in less than a minute (rather than 20 minutes which was suggested in the manuals). Is there a problem with the trade orders window in the sim setting? 2) I want to be able to trade so that I exit my last order FIRST (rather than first order first) - how do I do this? Thank you for your time |
[2020-06-11 19:25:38] |
1. In the case of simulated trading, you can only close/flatten the position from a chart Trade Window: Basic Trading and the Trade Window 2. What you are referring to is the matching of order fills after there are executions. You can control this with this Chart Setting: Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-11 19:26:03
[2020-06-25 17:58:03] |
Thank you for your reply. Does that mean that the trade orders window will be available during real trading? And if I have multiple positions open during a trade in sim mode, is there a way of seeing a list of my trades from the chart trade window and closing them individually? Thanks |
