Date/Time: Sun, 19 May 2024 03:48:01 +0000
Interactive Scale Move setting is not being saved
View Count: 568
[2020-06-10 04:32:16] |
User50927 - Posts: 90 |
The Interactive Scaling Mode on my charts keeps re-setting back to Interactive Scale Range whenever I restart the program, even though I set them to Interactive Scale Move before I saved and closed the program. I never had that problem before so I don't know what to do to fix it. Thanks.
[2020-06-10 04:34:33] |
Sierra_Chart Engineering - Posts: 14423 |
We will look into this. It may relate to the new Chartbook format.
[2020-06-11 12:32:47] |
nosast - Posts: 290 |
Same issue here
[2020-06-11 14:06:10] |
The problem appears to be gone now with the latest update (v 2119)
[2020-06-11 14:26:19] |
STill had this issue this morning with v2119
[2020-06-12 10:29:56] |
This will be resolved in version 2120.
[2020-06-15 16:48:17] |
I must have some option activated as it always defaults to move instead of scale. You are sure it's fixed in current prerelease 2021?
[2020-06-15 19:16:48] |
Yes it is definitely resolved. This is verified.
