Date/Time: Sun, 19 May 2024 06:12:08 +0000
Stop limit orders
View Count: 2296
[2020-06-09 14:29:16] |
User656746 - Posts: 10 |
Hi, how can I make use of stop limit orders per default? For example if I want to enter a market with a stop limit buy and use a protective regular sell stop market order at the same time on a DOM and also on a "small ladder DOM" as you can see below WITH a single click! http://www.sierrachart.com/image.php?Image=1591709856906.png This is how it looks like from my end when I use a buy stop limit order with a take profit limit order and a protective sell stop market order by using right clicking about the market on the Buy column. http://www.sierrachart.com/image.php?Image=1591710118471.png But when I right click above the market on the small ladder on the right side of the chart window ONLY a regular stop order is initiated as you can see below http://www.sierrachart.com/image.php?Image=1591712319546.png How can it be arranged that for "the small DOM ladder inside the chart" a stop limit oreder is issued too? Also, as for an attached protective stop I would always like to use a regular stop market order! Many thanks in advance! |
[2020-06-10 10:53:09] |
Refer to the 8 settings starting here that define the action taken when clicking on the Chart DOM Buy/Sell columns: Global Trade Settings Windows: Left Click on Buy Column Above Last (Global Settings >> Chart DOM Settings >> Order Types >> Order Types Above/Equal Last for Chart DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-10 20:28:08] |
Thank you! But how and where can I choose the limit price to be the same as the stop price? By default the limit price seems to be 4 ticks higher as you can see here: http://www.sierrachart.com/image.php?Image=1591820827192.png |
[2020-06-11 04:56:05] |
This is done through the Set tab of the Trade Window. This is explained here: Order Types: Stop-Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-11 05:30:20] |
Thank you! It seems I missing something here because I set the Limit to the stop price and it still shows the 4 tick difference! http://www.sierrachart.com/image.php?Image=1591853390850.png |
[2020-06-11 19:05:19] |
You must be changing the setting on the wrong Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM (Trade Window Settings Not Applying to Chart or Trading DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-11 19:07:00
[2020-06-11 20:57:20] |
Hi, I am afraid but I am lost! I could not find any information regarding the default stop limit settings on the link you were mentioning!
[2020-06-12 10:03:05] |
Could you please go to this page: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM And read the section titled: "Trade Window Settings Not Applying to Chart or Trading DOM" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-15 19:04:44] |
I found it finally! Thank you for your patience!
