Date/Time: Sat, 18 May 2024 20:43:29 +0000
Quote board header column font color
View Count: 762
[2020-06-08 22:03:02] |
Chris32 - Posts: 50 |
Hello, On the quote board : How to modify the color of the font and background on the column headers (the very first row)? I can't find it in global graphic settings. Thank you Date Time Of Last Edit: 2020-06-08 22:04:38
[2020-06-09 01:28:38] |
seandunaway - Posts: 214 |
Size too please (or just let me hide it)! :)
ugly quoteboard header.png / V - Attached On 2020-06-09 01:28:32 UTC - Size: 20.81 KB - 240 views |
[2020-06-09 09:02:31] |
Interestingly, it seems that I was able to modify the default background color sometime in the past, but I have no idea how (does the color come from sierra chart or from windows theme?). It leaves me with a bit of a contrast problem.
[2020-06-11 18:16:53] |
We will look into this.
[2020-06-15 18:52:18] |
We will prepare documentation on this, but the header colors can be fully controlled through Global Settings >> Graphics Settings. The items in the list begin with "List Box Header".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-16 07:52:31
[2020-06-15 22:06:02] |
Will font size be available?
Date Time Of Last Edit: 2020-06-15 22:06:48
